This requires a post processor edit. To allow code snippets to be posted manually using the Manual NC > Pass Through operation, please add the following function to the post processor using a text editing program.
1 2 3 4 5 6 7 8 | function onPassThrough(text) { var commands = String(text).split(","); for (text in commands) { writeBlock(commands[text]); } } //Thanks to the Autodesk Knowledge Network for help with this at https://knowledge.autodesk.com/support/hsm/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-use-Manual-NC-options-to-manually-add-code-with-Fusion-360-HSM-CAM.html! |
