Tormach PCNC 1100! Tormach PSG! Emco V13 Lathe! Solidworks! Sprutcam!
A customer had a worn-out aluminum bracket used to drive a crank arm off a motor. Using the Tormach PCNC 1100, the Tormach Personal Surface Grinder and Emco V13 lathe, we made a much stronger replacement bracket include a custom shoulder bolt to accommodate the fact that the bracket could not be expanded on the left hand side due to machine clearance!
A good example of balancing an improved design, pride of workmanship but also getting it done efficiently!
Machining a Porsche Turbo Gas Cap!
Picatinny Rail from Drawing to 3D Model in Fusion 360 – FF113
CNC Lathe Turning: Solid of Constant Width!
