How to Deburr Metal Noga Deburring Set This is a great starter set that includes the NOGA standard edge deburring tool, round hole tool, scraper, inside hole tool, sheet metal and keyseat tool! NOGA Reversible Countersink That burr raised by drilling or tapping into an internal shaft, hole or cylinder? THIS IS THE TOOL for you! Pushing the bottom straightens out the blade so that the tool can slide through the hole, then the blade pivots out to debur the hole! The RC1000 does 0.12″ to 0.21″ (3 – 5.5mm). The RC2000 does 0.197″ to 0.394″ (5-10mm) Noga H.D. RotoDrive Great for deburring round holes, such as backside burr left by drilling! Post Views: 6,474
