Using Fusion 360 CAD to sketch and model a basic knife blade for a fixed-blade knife! This tutorial shows basic sketching as well as sketch tricks to switch from sketching a line to an arc, then adding dimensions the sketch, then extruding to a 3D solid model of the basic knife blade shape.
After the basic profile of the knife blade has been extruded, we sketch a line to use as a sweep cut to add the bevel to the knife blade.
Fusion 360 Commands used:
- Sketch Constraints
- Symmetric Extrude
- Plane along Path
- Sketch Project
- Slice View
- Sweep and Loft with Guide Rails
Click to download Knife Blade PDF Drawing!
