Recovering from a devastating discovering:
a rusted surface grinder table. Follow along as we wire wheel, scrap, grind, clean and adjust to get the Okamoto Surface Grinder back in good working order. Finally, checking the results with a 5-block test!
Parallel Fail! We goofed! Machining & Grinding a 24″ Parallel. WW129
How to Prevent Rust in the Machine Shop!
DIY Repeat-O-Meter
