PLEASE READ! IMPORTANT SAFETY NOTE REGARDING LITHIUM POLYMER BATTERIES!
Click HERE to download The Imperializer Fusion 360 Solid Model CAD file!
The Imperializer!
Imperializer Assembly Video
Bill of Materials:
Small Parts List
Screws
- (6) 2-56 x 1/4″ BHCS Screws
- (2) 2-56 x 5/16″ FHCS Screws
- (2) 2-56 x 1/4″ FHCS Screws
- (2) 4-40 x 1/4″ FHCS Screws
- (2) M3 x 6 BHCS Screws
- (2) 4-40 Nuts
Electrical Components
- (2) 10KOhm, 1/4W, 5% Tolerance Resistor
- (1) NPN 2N3904 Transistor
- (1) 1N4148 Diode
- (1) 7-Pin Header
Misc Components
- (2) 12mm x 3mm Magnets
- (2) 1/8″ Nylon Spacers
Imperializer Arduino Circuit Layout
Troubleshooting
LCD backpacks with the PCF8574AT chip use the address 0x37, while those with the PCF8574T chip use 0x27. If upon uploading the code to your nano, the LCD flashes a row of blocks on the upper row then goes dark, try the i2c address change mentioned in the comment at line 19.
Required Libraries
Only one library is not available from within the arduino IDE. Download and copy the ‘NewLiquidCrystal’ folder to program files/arduino/libraries.
Click here to download the NewLiquidCrystal library
Arduino Code
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 | /* || NYCCNC IMPERIALIZER || -version 1.5 || -author Ed Rees || -1/15/2018 || -Copyright Saunders Machine Works, LLC 2018 */ // required libraries below. If necessary, search for them from the dropdown menu 'Sketch>Include Library>Libraries Manager' and install from there as prompted. #include <Wire.h> // included with IDE. #include <avr/sleep.h> // included with IDE. For whatever reason it doesn't turn orange like most libraries do, but it works fine. #include <Keypad.h> // by Mark Stanley and Alexander Brevig, can be found in the libraries manager. #include <LiquidCrystal_I2C.h> // available at https://arduino-info.wikispaces.com/LCD-Blue-I2C#v1 LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address to "0x3F". If LCD display is blank, try changing I2C address to "0x27" float entry = 0; // whole number value. float a = 0; float b = 0; float c = 0; float d = 0; float decimalValue = 0; // total decimal number value. float decimalEntry = 0; // most recent number entered while in decimal mode. float cursBreak = 0; // breaks main loop to position cursor. int decimalPlace = 0; // records decimal place for decimal value calculation. int keyCount = 0; // counts key presses to prevent overflow. int toggleState = 0; // records state of unit toggle switch. int cursorCount = 0; int cursorRow = 1; int divisor = 0; // used for unit conversion math. int sleepDelay = 15000; int sleepTimer = sleepDelay; int toggleLatch = 0; // current state of the button. int lastToggleLatch = 0; // previous state of the button. const int togglePin = 11; // declares digital pin 11 as unit toggle pin. bool decimalMode = false; // toggles between Inch to Millimeter and Millimeter to Inch conversion. bool decSkip = true; // used to skip cursor decimal count when entry is less than one. bool decLatch = false; // used to avoid cursor moving undesirably when decimal button is pushed more than once per entry. bool wakeMode = false; bool cursorBump = true; char customKey; const byte ROWS = 4; const byte COLS = 3; char keys[ROWS][COLS] = { {'1', '2', '3'}, {'4', '5', '6'}, {'7', '8', '9'}, {'C', '0', 'D'} }; byte rowPins[ROWS] = {9, 4, 5, 7}; // connect to the row pinouts of the keypad byte colPins[COLS] = {8, 10, 6}; // connect to the column pinouts of the keypad Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS); void setup() { pinMode(togglePin, INPUT); pinMode(3, INPUT); pinMode(13, OUTPUT); digitalWrite(13, HIGH); lcd.begin(16, 2); lcd.clear(); lcd.print("0.0000"); lcd.setCursor(0, 1); lcd.print("0.0000"); if (toggleState == HIGH) // determine initial unit toggle state and set cursor row accordingly. { cursorRow = 0; } else { cursorRow = 1; } } void loop() { customKey = customKeypad.getKey(); toggleState = digitalRead(togglePin); toggleLatch = digitalRead(togglePin); a = (entry + decimalValue); b = (a * 25.4); c = (a / 25.4); d = a; if (sleepTimer <= 1) // puts device to sleep when sleep timer runs out. { pinMode(8, OUTPUT); digitalWrite(8, LOW); sleepNow(); } if (toggleLatch != lastToggleLatch) { sleepTimer = sleepDelay; // reset sleep timer if unit toggle is changed lcd.begin(16, 2); lcd.setCursor(0, 0); if (toggleState == HIGH) { cursorRow = 0; } else { cursorRow = 1; } lcd.clear(); cursBreak = d + .5; } if (cursBreak == d) { lcd.setCursor(cursorCount, cursorRow); lcd.blink(); } switch (customKey) { case '0' ... '9': sleepTimer = sleepDelay; // reset sleep timer if a key is pressed. if (decimalMode == true) // determine if in decimal entry mode: { if (keyCount < 7 && decimalPlace < 4) // prevents overflow. { keyCount++; // increment key press count by one. cursorCount++; // increment cursor ount by one. decimalPlace++; // increment decimal place by one. divisor = 0.5 + pow(10, decimalPlace); // divisor is set equal to (10^decimalPlace), plus 0.5 to ensure proper rounding. decimalEntry = (customKey - '0') / (float)divisor; // decimal entry set equal to key entered, and divided by divisor. decimalValue = decimalValue + decimalEntry; // new decimal value set equal to previous decimal value plus last decimal entry. } break; } else { if (keyCount < 7 && decimalPlace < 4) { keyCount++; if (entry > 0) { cursorCount++; } if (entry <= 9 && entry > 0 && cursorBump == true) { cursorCount++; cursorBump = false; } entry = entry * 10 + (customKey - '0'); // increments digit input position. ie: 1(*10)+5 = 15. } break; } case 'D': //collects decimal keypress. decimalMode = true; cursBreak = (d + .5); if (decLatch == false && entry == 0) { cursorCount++; } if (decSkip == true) { cursorCount++; } decSkip = false; decLatch = true; break; case 'C': // clear- reset relevant variables to defaults and return to title screen. if(wakeMode == false) { cursBreak = d; entry -= entry; decimalMode = false; decimalPlace = 0; decimalValue -= decimalValue; decSkip = true; decLatch = false; keyCount -= keyCount; cursorCount -= cursorCount; cursorBump = true; lcd.clear(); lcd.setCursor(0, 0); lcd.print("0.0000"); lcd.setCursor(0, 1); lcd.print("0.0000"); break; } } if (toggleState == HIGH && cursBreak != d) // if toggle is in inch mode: { lcd.setCursor(0, 0); lcd.print(a, 4); //in lcd.setCursor(0, 1); lcd.print (b, 4); //mm } else if (cursBreak != d) //if toggle is NOT in inch mode: { lcd.setCursor(0, 0); lcd.print (c, 4); //mm lcd.setCursor(0, 1); lcd.print(a, 4); //in } cursBreak = d; sleepTimer -= 1; //counts down from sleep delay value. if (wakeMode == true) // upon waking, reset relevant variables to defaults and return to title screen. { pinMode(togglePin, INPUT); pinMode(13, OUTPUT); digitalWrite(13, HIGH); lcd.begin(16, 2); if (toggleState == HIGH) // if toggle is in inch mode: { lcd.setCursor(0, 0); lcd.print(a, 4); //in lcd.setCursor(0, 1); lcd.print (b, 4); //mm } else //if toggle is NOT in inch mode: { lcd.setCursor(0, 0); lcd.print (c, 4); //mm lcd.setCursor(0, 1); lcd.print(a, 4); //in } wakeMode = false; } lastToggleLatch = toggleLatch; } //Sleep functions below: void sleepNow () { digitalWrite(13, LOW); set_sleep_mode (SLEEP_MODE_PWR_DOWN); sleep_enable (); // enables the sleep bit in the mcucr register attachInterrupt (digitalPinToInterrupt (3), wake, LOW); // wake up on low level on D3 sleep_mode (); // here the device is actually put to sleep detachInterrupt (digitalPinToInterrupt (3)); // stop LOW interrupt on D3 } void wake () // interrupt service routine in sleep mode { sleep_disable (); // first thing after waking from sleep: sleepTimer = sleepDelay; pinMode(8, INPUT); wakeMode = true; } |
HEX upload via Xloader
You may also simply upload the compiled HEX file directly to the Nano using Xloader.
Click here to download Xloader
Click here to download the HEX file
Use these settings, change the COM port to that which your Nano is connected to, and navigate to wherever you unzipped the HEX file.
